AirMagic is Now Skywares
Re: AirMagic is Now Skywares
Alpha,,,,,where are u?????
Waiting for price.......
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
- Alpha
patience is a virtueScorpio wrote:Alpha,,,,,where are u?????
I will post before the end of the week...
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
EIShhhhh, to sien die week sy Golf Alpha Tango
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
- Alpha
En so is dit...Scorpio wrote: EIShhhhh, to sien die week sy Golf Alpha Tango
The cost for For the Skylink system only (Ex Chatterbox) is R2000 per system. That will include the plugs to GA systems and the straight cables.
How does that sound?
Nuwe week nuwe woema...lol
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
- Leprachaun
So guys whats up, will be interrested in a set that works gimme a call Gavin leprachaun
- Alpha
RepliedScorpio wrote:Alpha please check.....PM sent
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
Did not receive anything at 7.10pm. Maybe send again
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Sorry Alpha,,,,found your reply,,,Thanx
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
Hi Alpha,
I've just joined the forum from the UK as I found this thread when hunting for AM. I had a full set of their kit which I sold with my old plane. It did work very well and I'm pleased to hear you have taken on the business.
I have few questions:
1. Are the new headsets ANR or can you do an ANR version? I have a very noisy albeit enclosed cockpit
2. I have a Jab engine which gives off loads of interference (as well as noise) so need something to resist that if possible (the AM kit worked wonders with a similar but lesser problem with a Rotax 5820
3. Would you ship to the UK?
Look forward to hearing from you.
Sean
Sean
- Alpha
Seanxair wrote:Hi Alpha,
Sean
Hi Sean,
i sent you a PM
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
- Alpha
Hi Scorpio,Scorpio wrote:Alpha please check.....PM sent
PM sent regarding your order
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
Nou wat het van die Alpha oukie geword? Hoop nie hy is in die hospitaal nie
Thunderbird
Bushbaby in rebuild
Bushbaby in rebuild
- Alpha
Hi Scorpio,Scorpio wrote:Nou wat het van die Alpha oukie geword? Hoop nie hy is in die hospitaal nie
Nog hier, besig om 500 PCB's te populate met die surface components. Ek wil seker maak ons het genoeg voorraad en spares indien nodig, sodra jou stel gereed is sal jy die eerste een wees wat sal weet.
Ek vra om verskoning oor hoe lank dit vat.
Gary aka Alpha
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
Hallo Gary.Kan jy my asb kwotasie gee vir v rabbit atenna vir vertex 220.Ek het al die konneksies behalwe vir die v rabbit.Groete Johan Henning.
Users browsing this forum: No registered users and 91 guests
