Rhino Park APs (Jabiru engine rated)
Whee! The CAA song and dance is happening again...
Can anybody recommend a mobile AP who serves the Rhino Park area, and is rated on Jabiru engines? Seems Monty is no longer an AP (I know he was planning on leaving the country).
Thanks,
Justin
Thanks,
Justin
Re: Rhino Park APs (Jabiru engine rated)
Hi Justin, Monty has left the country a while ago. Try Johan Lok he might be able to refer you to someone or you can also try Leon from Springs.
Btw where did you buy the mesh you used for you filters? I have had no success finding any.
justin.schoeman wrote:Thanks Sailor.
I think I got it from http://www.wiremesh.co.za/ - but it was a long time ago.
PS - I do have some mild steel mesh that can also be soldered - but the coating needs to be cleaned off....
Thanks Justin, will keep on looking.
Hi Justin,
Isn't Phillip at Zynkraal a Ap rated on Jabi's, know Stefan of KFA at Petit is maybe he can help?
JvTonder wrote:Hi Justin,
Philip isn't an AP - he used to use Monty, but has not found a new guy yet. Not sure about KFA - but last I checked he was a bit busy for call-outs...
Following up on the other leads - thanks all.
Justin, This is a good excuse to fly down to Munster or Margate, for a few days holiday. I would be able to do it for you.
vernon11 wrote:Justin, This is a good excuse to fly down to Munster or Margate, for a few days holiday. I would be able to do it for you.
If the plane still had a valid PFA, then the annual would not be a problem (plenty of fly-in APs around). Even considered a special flight permit to fly it in to an AP - but you need an AP to inspect the aircraft for a special flight permit application .
- BUKS VAN NIEKERK
hi Justin,
have you tried uncle Fred Blokland at Brakpan Airfield?
Regte manne skiet nie renosters om n horing te kry
- goldie
Willie Van Wyk zero 72 317 7768 He does my Bantam (80hp. Jab.) on our farm near Harties.
Stays in Pta. so Rhino shouldn't be a problem for him.
He is booked up 2/3 weeks in advance and can only do on Sat or Sun.
Hope this helps,
Mike
Hope this helps,
Mike
The great thing about getting older is that you don't have to prove yourself anymore.
Hi Justin,
What do you need done? If you don't find anybody, I will fly to Rhino and help you.
Stefan
Stefan
Thanks Stefan - just need a new annual inspection... May have something sorted out for tomorrow though. Will let you know if I don't come right.KFA wrote:Hi Justin,
Stefan
Thanks,
Justin
- Duck Rogers
Recommended. I've got mesh from them before. Very helpful and knowledgeable people and they'll also sell you any size as well.justin.schoeman wrote:Thanks Sailor.
Thanks everybody for the tips and advice. Annual done, be back flying soon!
